Timing question
Will the mark on the cam sprocket and the marks on the flywheel all line up exactly? When I disassembled everything, my cam sprocket was off a little (a few teeth on the sprocket) when I had the flywheel lined up. Is this normal?
When installing the new belts, all of the marks should be lined up ... correct?
