Benchtesting fuel pump?
I have no fuel pressure ( and no fuel) in the fuel rail in my early 85 944. Tried to jump the fuel pump relay and all that did was blow the horn when I put the jumper on it ( please tell me thats normal and not some home wiring from the PO).
So I pulled the fuel pump. Lotsa brown crud in the pump itself ( the car has been sitting for 5 years) even tho there is new fuel in the tank.
When I attach 12v to the pump it jumps and hums but doesnt feel like its turning. When I look in either end nothing is moving.
When I stick the suction side in fuel -- nothing comes out the other end.
So the questions--
Does the pump have to be lower than the fuel to work?
What amps does the pump need to work properly?
What are the specs on the pump -- rate of flow/pressure etc.
Im tryin real hard not to shell out the chunk-o-change for a new one unless its bad.
So the questions--
I bench tested mine out of the car running 12v to it and it worked fine, so I think you may have an issue with yours. Mine was pretty gunked up as well in the check valve which was 95% of the reason I changed it anyway...I figured if I had it out for the check valve, might as well replace it with a new one. My pump (it's stock and when I took it out my car had 82k on it) works perfectly - you'd just need the check valve. I also have a brand new bigger pump (it's the 928 pump) that I bought and ended up not using it. It fits the 951 perfectly - just has a slightly larger end for the hose that connects the pump to the fuel tank - other than that - it's the same, just flows a bit more fuel...
PM me if you need either of them...
