sproing!
buy a used one or try to find the cap that came off... If you look into the hole you have you will see a threaded rod. the plastic button has got stripped threads.... should be an easy fix
Hey man thanks a million for the tip. I did as you said and it is fine now. Hell I remembered int he doc's parking lot this morning and did it from the driver's seat!
Thanks again. <img src="graemlins/beerchug.gif" border="0" alt="[cheers]" /> <img src="graemlins/beerchug.gif" border="0" alt="[cheers]" />
