968 MO30 sway bars with delrin bushings
i finally got around to installing the racer's Edge delrin bushings on my 968 MO30 sway bars . The rear bar's bushings come with their own brackets which are very nice by the way but the front ones don't and they do not fit properly on the stock 944 bushing brackets.Should I be running a different bracket or is there a trick to it?Any information will be appreciated as I need to fix this before this saturday auto-x
My front ones fit very well. Is it possible that your brackets are worn? If you got them from Paragon, give Jason a call and talk to him about it. The rear assembly was really a Good fit though.
thanks Skip ,I just left a message for Jason.The rear one fits perfect!
Paragon!
where else ?
where else ?
