944 Aluminum Pedals - Direct Replacement?
I did a search on this topic, but didn't find a concrete answer:
- Are there any aluminum type pedals (clutch, brake, gas) that are a direct replacement for the rubber stock ones?
I have found plenty that you drill into the current pedals, but just wanting to find ones that are a direct replacement.
Couldn't find any when I was for some looking but that a few years back but no big deal even if you have to drill - 4 little holes " 1-brakes-1clutch -2gas.
Rennline does make a direct replacement gas pedal though. Expensive.
I found a thread that talks about using the Audi TT pedals for the brake and clutch and it is a direct replacement, no drilling. Anyone use these with a gas pedal of another brand?
Now, just need to find a gas pedal that matches the Audi TT brake and clutch.... someone mentioned a sparco on the thread I found, but I can only find sparcos in sets....
