Adjustable Fuel Pressure Regulator
Has anyone purchased this item?
http://cgi.ebay.com/ebaymotors/Porsc...item4a96f80adb
If you have how did you attach it to the fuel rail?
Thanks in advance for any ideas
Pics weren't showing up for me, but it sounds like a universal adjsutable FPR. it wouldn't mount on the rail, you'd run it off the retern line and probably mount to your firewall or such.
The issue with my current FPR is it is not working.
Alxdgr8 if I understand what you are saying the original OEM FPR would stay and this would be in addition to it? If not what do you do with the old non-working FPR.
Thanks for any direction with this.
You could keep the stock FPR (but if it's not working that may not be a good idea), but then you wouldn't be able to lower fuel pressure below stock, only raise (much like a boost controller with a wastegate). Ideally you'd delete the OEM FPR and run only the adjustable so you could set it wherever you want.
Standard Bosch OEM FPR's are pretty cheap and even cheaper used. I would go that route.
