No start......... fed up now
944S2 1989
I'm fed up with this car by crikey .
6 weeks its sat unused and I have no other transport atm.
It really tried to start today. It coughed and fired coughed and fired but as soon as I gave it some throttle it stopped trying and just cranked over.
It must be very close or it wouldn't fire at all.
I jumpered the DME and could hear the pump, and cold start injector but not the injectors. maybe they are stuck with crud
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
1 Post
Peanut, find a place you can send the injectors off to have them refurbished, cleaned, new seals and hat. At least you will have one less problem. Have you checked the speed and reference sensor connections?
No Start Check List, I hope this will help.
This has been extracted from a past post, authors Billysdad and John_AZ on a Start Problem.
Re: 1987 starting problem
« Reply #1 on: Jul 25th, 2009, 10:28pm » Quote Modify
Hmmmm.... that could be alto! you really have to go step by step and check the ecu harness and voltages to each area as you go. Here is a list of some test you should do one by one and eliminate problems.
Air/fuel/spark/compression
start by making sure we have a battery that is in spec.
all fluids topped off
no obvious broken wires and all vacuum hoses intact on visual inspection.
OK we have 12v at the battery with adequate cranking voltage we get in and turn the key.
12v from battery to ignition switch
12v from pin 50 on switch to pin 4 on DME plug (start signal)
12v on pins 1 (ignition pulse to ign. coil) and 18 (to G5 dme relay power supply)
12v pin 30 at DME Relay (fuel pump power supply)
12v to pin 86 at DME Relay in the run position (primary coil voltage)
12v to coil + black wire to ground 12v to - (green wire) to ground
12v to one side of the injectors
All ground contacts are clean
Fuel pump will run if DME Relay is jumpered 30/87/87b
Fuel pressure at the rail is psi +/- 3 (jumpered 36 psig)
20 minute leak down not under 14.5 psig
Fuel flow rate is 28oz after 30 seconds
Ignition coil primary resistance across + and - is between .4 and .6 ohms
Secondary resistance is between 5000 and 7200 ohms
Ignition wires are good no cracks or splits including coil wire and seated
Plugs are properly gapped
Ignition rotor is seated correctly with the set screw
Timing belt is installed correctly
Firing order is correct - 1 - 3 -4 - 2
Reference sensors are gapped correctly with .8mm clearance off the flywheel
Reference and speed sensors resistance checks in spec pins 8 and 27 speed 600-1600 ohms and pins 8 and 23 >1m ohm
Reference and speed sensors voltage checks 2.5 and 2v on oscilloscope (good luck)
Reference and speed sensor wiring is not broken at connector to sensor or to dme
OK, I'm tired anyone else want to add or be more specific?
John_AZ
Do a compression test.
Reference Sensor Tach bounce when attempting to start the engine. The Tach bounce is very slight-1/16 of an inch. Clean connections as mentioned above.
Injector "noid" light. Very basic tool but will tell you if the DME is sending a signal to the injector. An oscilloscope is the best.
Clean connections at major parts like AFM, ISV, throttle body.
Cheers,
Larry
John_AZ
Cheers,
Larry
I've checked so much so many times my head is spinning.
I've lost the will to live Larry
You are right about the injectors of course. I am lucky that there is a place locally that will clean and check them (10 miles away)
only problem I'm out of work and broke so I'm reluctant to get my injectors back with a $200 bill for clean and test and a message saying I need 4x new injectors at $250 each.
I think I'm going to have to bite the bullet and remove the fuel rail with injectors and test them in situ .Rotton job when its cold and pouring with rain and you're working outside
start by making sure we have a battery that is in spec. yes
no obvious broken wires and all vacuum hoses intact on visual inspection. yes
12v from battery to ignition switch yes
12v from pin 50 on switch to pin 4 on DME plug (start signal) terminal 30 yes
12v on pins 1 (ignition pulse to ign. coil) and 18 (to G5 dme relay power supply) terminals
12v pin 30 at DME Relay (fuel pump power supply) yes
12v to pin 86 at DME Relay in the run position (primary coil voltage) DME removed and jumpered yes
12v to one side of the injectors not sure? will check
All ground contacts are clean must do but hand won't fit grrr
Fuel pump will run if DME Relay is jumpered 30/87/87b yes fuel gushes continuously through FPR
Fuel pressure at the rail is psi +/- 3 (jumpered 36 psig) 3xbar yes
20 minute leak down not under 14.5 psig mmm not checked yet
Fuel flow rate is 28oz after 30 seconds yes more like 2 lts
Ignition coil primary resistance across + and - is between .4 and .6 ohms must check
Secondary resistance is between 5000 and 7200 ohms must check
Ignition wires are good no cracks or splits including coil wire and seated yes
Plugs are properly gapped yes
Ignition rotor is seated correctly with the set screw yes
Timing belt is installed correctly yes
Firing order is correct - 1 - 3 -4 - 2 yes
Reference and speed sensors resistance checks in spec pins 8 and 27 speed 600-1600 ohms and pins 8 and 23 >1m ohm can't reach sensors but will check ohms
Reference and speed sensors voltage checks 2.5 and 2v on oscilloscope (good luck) no sillyscope
Reference and speed sensor wiring is not broken at connector to sensor or to dme no
Reference Sensor Tach bounce when attempting to start the engine. The Tach bounce is very slight-1/16 of an inch. forgot to check
Injector "noid" light. Very basic tool but will tell you if the DME is sending a signal to the injector. will check (can't find noid lights)
Clean connections at major parts like AFM, ISV, throttle body.must do
Cheers,
Larry
Cheers,
Larry
I assume this isn't an old 924 with CIS and a cold start injector. If it is, you might check the 924 boards for help.
Have you tried a puff of "Start ya Bastard?" That'll help determine if it's fuel related.
Is it turning over faster than usual? If so it might have jumped time.
Check for the tach bounce
Does it have an alarm? Immobilizer?
Sorry its a 944S2 1989 .
Tomorrow I'll check the HT system again and the tach bounce but I'm dreading removing all the console to get at the immobilser. I'd like to remove it completely one day when I've taken enough brave pills
