Painting gauge cluster light tunnels?
iPod Tamer
I was thinking about painting my gauge cluster light tunnels instead of the foil method to brighten things up again. What do you guys think of using some chrome or reflective silver paint on them?
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
1 Post
Not a good idea. Go with the reflective tape/aluminum foil for best results, and make sure the reflector sides are fully covered. I believe the bulbs are #194, not the LL's. Do the Search as there are plenty of write ups on it. Here is a great DIY.
https://rennlist.com/forums/944-turb...e-writeup.html
Cheers,
Larry
Cheers,
Larry
i painted mine with a chrome/ mirror paint and it works great and then covered with black paint to help. i see no differnce between the way i did it and using mirror. as i tried that at first.
I used 'chrome' paint and it helped get the dash lights back to good brightness. I have also used aluminum foil. Seemed about the same. Don't try really powerful bulbs as they will melt the sockets.
It's best to take the light tunnels off the cluster, or you might get some overspray on the inside of the bezel.
