X-post - Anyone in the DFW area have an OPRV alignment tool?
You don't need the alignment tool. Install the housing with the bolts finger tight. Install OPRV making sure that you can thread it in easily. If you need a wrench, the bolts for the housing are too tight and not allowing it to float as you install the valve. Once you have the valve installed, carefully tighten the bolts a bit at a time being sure not to disturb the alignment.
