Instrument Cluster
I finally found time to dig into my not working speedometer. I pulled the cluster out (NOTE: ignore factory manual telling to remove steering wheel - cluster could just be "wiggled out" ).
Well, PO really screwed up the speedometer - it is not repairable - needle's needle is broken. Odometer gear is broken as well, etc.
Anyways, my question is: does anybody know the connector pinouts (in particular I am looking for speedometer signal pins -manual's schematics is unclear) on the back of the cluster. Using DVM and a voltage source I was able to figure out most of the gages and lights, but can't verify speedometer signal comes to the cluster ok...
For those who are familiar with it there are 3 17-pin connectors in the back (A,B and C)...
Thanks.
Thanks.
