Changing _some_ of the coolant
Location: Ex. Vestal, NY; Binghamton, NY; Los Angeles, CA; Poway, CA. Now, somewhere else :)
Had the heat valve explode, repaired it with a steel tube, filled up with tap water and drove home from the track. A new heat valve is installed and a quart of Porsche coolant is ready to go in. What is the easiest way to get a quart of water out of the system?
well u don't want to just add coolant. u need to flush out the entire system. tap water will leave mineral deposits on inside of your radiator, which will reduce the heat conductivity.
u need to drain all of tap water and refill it with proper coolant mix. either 50/50 antifreeze or distilled water. and a QUART isn't going to fill up anything. coolant system has a capacity of like 2 gallons.
Thing is, when you blow the heater disc valve, you don't empty the entire system (It sits above the water pump). The quart I've got is pure, undiluted, 100% anti-freeze. That's why I want to try with one quart first, measure the freezing point, and adjust if necessary. Tap water here is Long Island pure, so I don't worry too much about deposits.
I had brand new coolant less than two months prior to the "explosion", so I want to try the easy (lazy) way first
bearone: when emptying the expansion tank and re-filling it with anti-freeze, will the anti-freeze mix with the rest of the coolant just by running the engine?
Thanks again
Thanks again
it'll eventually dissipate in. but the tank isn't part of the flow.
u could try to get some kind of fitting or a small funnel to pour it into the bleeder hole....but that's really jerry riggin it hehe.
Yes the new AF in the tank will mix with the rest. I agree that you don't need to flush. The ratio of AF to water isn't that critical unless you live in Fairbanks (AK).... I've never bothered with distilled water either - city water seems to work just fine.
Thanks again
Thanks again
if the tank isn't part of the flow why does the level come up as you get up to operating temp? isn't that why you add water/anti-freezewhen it's cold? doesn't the tank have both in/out?
well the two outlets go on either side of the radiator...so it's not really part of the flow as i see it.
well u'd try to avoid opening up the system when it's hot...cause it'd geyser when u open the cap and there'd be coolant everywhere and u'd get steam burns heh.
It's been unbelievably cold here for a few weeks, but there aren't any signs of problems with the coolant, so the input I got in this thread seems to have worked. Thanks
Yes, topping up coolant is a good thing. Refreshes the additives. Changing it is necessary, perhaps at timing belt time, but if your system is not leaking and a total drain and refill is a long ways off it's a good idea to get a couple quarts of new coolant in there maybe every year or so.
For water, I use distilled water from Wal Mart but my tap water is not municipal.
If you need to make room for some fresh coolant, a suction gun or a wet-vac does a good job.
-Joel.
-Joel.
