Odd clicking from the rear only under power...
Old 03-24-2003, 02:28 PM
Tremelune
Tremelune's Avatar
Post
Alright, alright, Haynes is telling me to pull the sucker off the car...I saw a 5 minute fix and my eyes glazed over. And now that I know what's up, I can search the archives...
Old 03-24-2003, 04:05 PM
Wachuko
Professor of Pending Projects
Wachuko's Avatar
Post
With the write up in Clarks Garage and the Haynes Manual you should have all the answers. It is really a simple task, like I said, just a mess in terms of dealing with the grease.
Here is a foto of the bolts, boot and socket:
<img src="http://groups.msn.com/_Secure/0SgCvBPAUnum9WmSNEo1Z4YQW*s279*k1pQklHj5R6yVbJj7Q52GmsojiTMAY0P28DSoc!XP 5veTShkM!nH!rqGx9b*aIcgEfUjW5lCEF7x8HFJzLJ6xFnA/951-CVJ_0024.JPG?" alt=" - " />
Here is a look at the tranny without the CVJ shaft:
<img src="http://groups.msn.com/_Secure/0SgDeAvUUz!q9WmSNEo1Z4U4Owbo3HyVvESx1e4e5*hjwXggx8jtMQlYwvZhui7gQbE!VXcT wAKA6dVudjOvv91r5aPssmCDwNtFQZc*tN6yapLvF39PIsA/951-CVJ_0029.JPG?" alt=" - " />
And the end of the shaft with the CV bearing in place:
<img src="http://groups.msn.com/_Secure/0SgCzBPQUkeq9WmSNEo1Z4e4mFweFkUYGw7Mh3oP7Yb03GMqbQdGBSYwsi81T*6aRz*RHATL Yz1hKX4wi8HaE2r4KeaY0TePPQROXqVRFnhdmQ63laiMa3A/951-CVJ_0019.JPG?" alt=" - " />
Let me know if there is an specific photo you want...
Old 03-24-2003, 08:17 PM
Tremelune
Tremelune's Avatar
Post
Awsome, my man. Thanks.
Is there a reason there are cheesehead bolts on this thing? It seems rather...annoying.
Also, can I get comparable bolts at, say, Home Depot. I haven't checked them out, but I'm willing to bet mine aren't in the best shape.
Do I want to take the whole half-shaft off? I think it's only the outside joint...Is there a good way to isolate the prob with the car off? I guess I could just twist it and feel for a click...Oh yeah, drive the car on ramps? Jack it up? This will be interesting.
Latex gloves await...
Old 03-24-2003, 08:41 PM
RJP 951
RJP 951's Avatar
Post
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by Tremelune:
<strong>You swapped axles from side to side? I've never heard of that...Is this along the lines of rotating the tires? Is this something I might want to do "while I'm in there?"
As of Fall, the boots all looked good.
</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Yes, it's sort of like rotating tires.
As for removal... you definitely want to remove the whole axle. I can't imagine changing the joint while the other end is still connected to the transmission.
Ron
Old 03-24-2003, 09:08 PM
Highway T
Highway T's Avatar
Post
Mine made a hellish thump that would go away for a short period if I 'jiggled' them side to side.
Had them rotated and repacked with grease at the local Porsche dealer so it is proper solution. Apparently only one surface of the joint wears so by turning them over it evens out the wear. They charged $190 which didn't seem to bad to avoid such a dirty job.
Old 03-25-2003, 12:00 PM
turbo944
turbo944's Avatar
Post
When I was there at Autozone (only place in the area that sold the rear defroster fix kit...), I got the grease...it was a moly based semi-synthetic instead of just the regular stuff.
Yes, injecting is only buying me time....My thought is probably going to brand new axles when it starts again and doing both at the same time and being done with it, hopefully for many, many years.
Cheers!
Old 03-26-2003, 12:14 AM
Tremelune
Tremelune's Avatar
Post
Well, $20 to buy time seems pretty good to me...Who knows what'll go wrong in the meantime. <img border="0" alt="[ouch]" title="" src="graemlins/c.gif" />
Old 03-26-2003, 12:45 AM
turbo944
turbo944's Avatar
Post
lol....Too much Tremelune.....check my post in the 951 forum...Busted. Fog/Driving light that is. 4" hole in the glass!!!! Yikes!!!! My driver's side one has a crack in it anyway, so I get to drop $400 tomorrow for new ones and instead of just buying stock, I'm getting the Euro ones and some protective covers for them. Mine were getting a little hazy anyway.....and well you see.....
Cheers!
Old 03-26-2003, 09:55 PM
Devia
Devia's Avatar
Post
Just be careful, C.V. joints and boots are not to be played with. I just had fun with them on Friday!
I took my boyfriend's car in to have the C.V. boots replaced (Eagle Talon/Mitsubishi Eclipse), and the darn shaft came apart! Fortunately, the shop was in a generous mood, and felt it would take them more time to put it back together, than to sell the complete assembly with both boots on, for $110. I bought them a case of beer, for being so considerate.
Because it was a front drive vehicle, it was masquerading as a transmission problem, just felt like it was shifting hard.
I took a look at it, and the inner C.V. joint was very unhealthy, I think it would have dropped while my boyfriend was driving it. He thinks I'm great, but I think it was more like luck this time!
Now I've got to tackle the stupid oilpan and transmission gaskets, while looking for a 944 for myself, grr.
- Julie
Old 03-29-2003, 02:34 PM
Tremelune
Tremelune's Avatar
Post
Alright, just be clear, my plan was to remove both axles and swap them, but now I don't want to (I might get booted out of my garage today, yay). Should I put the axle I pulled off back on the same way or rotate it?
Like, should I put the outside to the inside and the inside to the outside, or should I just put it back on the way I pulled it off?
Old 03-29-2003, 07:56 PM
turbo944
turbo944's Avatar
Post
I think if you search back, you'll find that Danno has mentioned that rotating on the same side doesn't change anything because of where the wear occurs in each. Others have said it does help....guess it's one of those decisions we'll leave up to you
Cheers!
Old 03-30-2003, 07:32 PM
Tremelune
Tremelune's Avatar
Post
Woohoo! No more clicking! I ended up swapping the axles from left to right. Just seemed like a good idea without too much work.
I hope everything stays together for a while. A writeup with pics is in the works...
Old 11-21-2003, 12:38 AM
kennycoulter
kennycoulter's Avatar
ok i couldnt find my old post, but i bought new c.v. joints and installed them. at first, i thought the problem was the passenger side, but when turning it would make the clicking and clunking at the drivers' side. i only changed the drivers' side so far. followed all the rules, i did find a nick in one of the "races". the grease that WAS in there was like liquid. i read in i think clarkes garage that different greases break down other greases. i guess thats what happened from the last time i packed them. well from sunday to wednesday, everything was fine. on the way to work on thursday, i heard the clunking again. i only used the supplied grease with the lobro kits. i figured it WAS possible to over do the grease. does anyone know what is compatible? the clicking is on/off now and then like mentioned above. is it possibly transmission? i hope not, but im getting a new one for thanksgiving. please help.
Old 11-21-2003, 01:02 AM
kennycoulter
to the top.
Old 11-21-2003, 11:47 AM
kennycoulter
please
Quick Reply: Odd clicking from the rear only under power...
