I need a cam housing assembly
The hole for my cam sprocket bolt has damaged threads and the bolt won't stay tight. I figure the most cost effective fix is to find another assembly, rather than buy a new cam and lifters. Any suggestions?
OK I found another complete cam housing assembly for $100 if I need it. Has anyone ever drilled and tapped out the hole to the next thread size? Is that possible, i.e is there enough clearance on the cam?
