Another Clutch Pedal to the Floor
did my clutch master and slave saturday
cm= $125.00 advance autoif you want it now if not order from online
cs= $85.00 advance too
save you $40.00 on the hose and just get high pressure fuel line hose i did it to my car and it works great plus it was only $1.85
1 Post
dmalo810
i have never rebuilt a brake caliper, or anything for that matter, if i rebuild the master and slave, will it be pretty clear on what to do?
and id hate to spend the money, but im considering just replacing everything with new, so HOPEFULLY ill never have to worry about this again.
dmalo810
Now if you are on a tight budget, and don't mind having to do it again in a few months time, rebuilds are an option, and if you can open a can of skettios you can handle a rebuild... snap ring, pull it apart, clean it all up, install new bits, reassemble... usually takes about 20 minutes or so to do the rebuild, BUT if there is any damage to the inside bores, the rebuild won't last long...
http://www.rockauto.com/catalog/rafr...1263574k482812
BECK/ARNLEY Part # 0717611
MAJOR;Contains Piston, Dust Boots Not Included
and..no longer available..
hmmm..interesting....
1 Post
i've decided to just go buy a new slave tomorrow.
if that doesnt fix the problem, then ill get a new master cylinder also.
after i replace it, will i need to bleed the system? (never done it before so i dont know how)
Yes you will need to bleed the system after replacing either master or slave...
what is it? it's just like a brake bleeder. either a 7 or 8mm hex.
be sure to unhook the battery as you will be working in close proximity to the starter harness and the body. u don't want to arc weld your wrench to the car (ask me how i know)
NO, you shouldn't top off unknown fluid with a different type of fluid... this is a great time to do the recommended ANUAL brake / clutch fluid change... Yes it is recommended to change allt eh fluid out once a year!
1 Post
i know about unhooking the battery, who hasnt made their own fireworks show before?
i just ordered 1 litre of ATE super blue from pelican, i believe thats what i have now. how do i get all of the old fluid out and put more in? just keep pouring in the new stuf as the old stuff comes out of the slave cylinder?
yea pretty much. if yer old fluid is amber (or was amber at one time) and yer using super blue, it'll start coming out dirty amber....then streak of green..then eventually all pure blue.
Brakes should all be 8mm, the clutch is the odd one out... part of the winter round is going to be speed bleeder valves on everything! I already use my Motive power bleeder on the cars, and I love it...Motive PB, speed valves and some silicone vacuum line dropped into a gallon water bottle... fluid change out is done in 20 minutes or so!
