ABS s2's?
trying to work out if I have ABS and its working
DOH
anyone have a photo or know the location of the ABS pump.
I've never seemed to get that pulsing when braking when you would assume the ABS comes on
cheers
DOH
cheers
ABS pump is inside of the right front fender, at least on LHD cars. You should also have ABS system warning light in your dash.Also no pressure valve in brake master cylinder for rear brakes,ABS computer under dash and senors located all wheels should also be there if ABS equipped vechile.
