Most RPMs your car has seen?
Old 10-12-2009 | 04:16 PM
944Ross's Avatar
944Ross
Originally Posted by alordofchaos
Always disengage the cruise control before depressing the clutch
Not sure of the exact RPMs, but it did sound cool
Reminds me, I should rig up a clutch switch to disengage the cruise.
I thought they came with a clutch switch???
Old 10-12-2009 | 04:18 PM
Yabo's Avatar
Yabo
I've hit the ref limiter plenty of times , been 5 years since I've done any engine work. Who knows if its going to blow someday.
Old 10-12-2009 | 04:27 PM
MM951's Avatar
MM951
A few times (3-5) I spun it to a little over 7,200 rpm due to wheelspin in 1st or 2nd
Old 10-12-2009 | 05:00 PM
schwank's Avatar
schwank
Herr Unmöglich
Power does get sparse but I have run mine to 7K numerous times on the track.
Old 10-12-2009 | 06:56 PM
DarylJ's Avatar
DarylJ
You should already have one.....but, even if you don't, you still (should) have a rev limiter. I have no problem bouncing mine off of that, with no ill effects. Its there for a reason.
Old 10-12-2009 | 08:11 PM
Rogue_Ant's Avatar
Rogue_Ant
Small Business Partner
After 20years the rods have fatigued. The stock pistons are not exactly light either...
Anything over 7k is tempting fate with the stock bottom end...
-Rogue
Old 10-12-2009 | 09:00 PM
J Berk's Avatar
J Berk
I have hit the rev limiter several times on the track while accelerating hard on pit-out.
Not something I like to do, or do on purpose...but that's what the limiter is there for.
That said, I normally try to shift around 6k max.
Old 10-12-2009 | 09:32 PM
BeerBurner's Avatar
BeerBurner
Unbannable
I know I've bounced off the rev limiter with my stock chip but on the whole I tend to not go above the mid-6k's.
BB.
Old 10-12-2009 | 11:33 PM
nkgosselin's Avatar
nkgosselin
140k miles on my stock 83. First race, with the only engine prep being running 20/50 VR1 I did a 3-hour enduro. Lots of running at 6400. No problems. That is a Porsche.
Old 10-13-2009 | 12:10 AM
gtroth's Avatar
gtroth
Yup. That's what happened to me the only time I saw the red line. It had been a long, hard day, cruising home, and noticed the CASIS light on. Stepped on clutch to go to 5th...
Sure sounded great but scarred the crap out of me. Just tapped the brake.
Old 10-13-2009 | 12:24 AM
KLR's Avatar
KLR
Interesting. The factory definitely put one in there on my '87. I'm pretty sure that all years have a switch to disengage cruise if you step on the clutch. It would have been nice if they also rigged it to the starter -- I'll certainly admit to having turned the key while the car is in gear a couple of times. Harmless, but alarming.
Old 10-13-2009 | 12:33 AM
INURGRL951's Avatar
INURGRL951
From: out in the sticks and flat lands of va wondering around for an open field or pavement!!!
Well with my increased readline (8300rpms) before anyone starts barking I have loads of internals done. Even with that said I hardly ever get it up that high only on dyno pulls. I mostly shift at 6k I like my build/money/time invested to last.
Old 10-13-2009 | 12:35 AM
Dougs951's Avatar
Dougs951
Now here is a better question, How far can a reworked 944 rotating assembly and valve train go? Has anyone broken 10k and had the car last?
Old 10-13-2009 | 12:41 AM
Rogue_Ant's Avatar
Rogue_Ant
Costas, what head?
Old 10-14-2009 | 12:29 AM
INURGRL951's Avatar
INURGRL951
I seriously doubt 10k on a 8V head at least.
Rogue I am using the 8V head bigger valves, ported, polished, stiffer springs and solid lifters five angle valve grind. Each port was enlarged by 3mm (there a bouts) to increase the flow as well as the throttle body and stock intake was also enlarged to handle the flow. Before I change to an EMS I was using a chipset for SUPERCHIPS that could handle the increase in revs and bumped up my redline.
But when you increase your revs there is major work all around the motor to "adjust " the recirculating mass to help in your favor.
