Transmission Model ID..?
I did a search on Transmission Codes but all I can find is talk of the 5Y or other type coding on the Sticker...
And talk of finding the "code" on the top of the transmission...
But what and where on the transmission is the Model Code..?
The 88/6, A or 016/9, G, K, R, S, Y or 083D, F or G31/02
Where are these "Model" Codes located at or derived from..?
They are stamped into the transmission housing, on the top... there is a flat area that has the numbers stamped into it...
http://www.clarks-garage.com/pdf-manual/trans-04.pdf
I know that is what all people talk about and refer too is the 2 letter code and the build date; dont care about that...
I want to know where the "Model" Numbers are at on the transmission..?
Like:
88/6
88/A
016/9
016G
016K
016R
016S
016Y
083D
083F
G31/02
Where are these Model Codes at..???
Like:
88/6
88/A
016/9
016G
016K
016R
016S
016Y
083D
083F
G31/02
From the link I gave you... as compared to the example pic I provided you...
Type
016R--
Code:
5P--
Model/Year:
944 Turbo (1985 -1988)-
Gear Ratios :
1st ................2nd ..............3rd ...............4th ................5th ...............Rev ..............FDR--
10:35 (3.500) 17:35 (2.059) 25:35 (1.400) 29:30 (1.034) 35:29 (0.829) 12:42 (3.500) 8:27 (3.375)--
Comments:
With Oil Cooler Standard - 85/86 Optional - 87/88
Type
016R--
Code:
5P--
Model/Year:
Gear Ratios :
Comments:
