Hey now mine just shut off WTF
One way to check to see if its a fuel problem is to use starting fluid when its not running. If it starts on starting fluid, then check fuel pressure. If pressure is good at the rail, then check for injector pulse. If you have pulse at the connector, then its your injectors, though unlikely all 4 will go bad at the same time. If the pressure is not there, then it could be your filter, pump, ground, or power to pump(maybe relay). Good luck.
