Engine wont start-Starter issues
So I just reinstalled my engine got everything wired back correctly, I think. I have lights in the car, headlights work, however when I turn the key I just get a click. Battery was old, but charged, even tried jumping it with another car. I just get a click. Even tried 2 different starters, same results. Is there another wire I missed? I have the 1 red positive and 2 black negative wires.
I got it to "whir" once for about 1/2 a second and then just "click" Anyone run into starter issues in the past?
Proprietoristicly Refined
You problem sounds like contacts if the starter was fine in the past. Do you have a remote starter switch to bypass the ignition switch?
I do not like to jump our cars. The DME and related electronics could burn out.
Have the battery tested at a local parts store. WalMart sells a 3yr for $65 or go with a Bosch or similiar.
GL
John_AZ
GL
John_AZ
