I'm retarded...
So I just replaced my head gasket, but I forgot to remove the starter to turn over the engine while setting TDC and doing the belts. What harm could I have done? The car still starts and it didn't feel like much resistance to turn it over (with the starter still in).
You only need to remove the starter to use a flywheel lock. Unless you have the key turned to the "start" location (and the starter's spinning) the starter's gear is retracted and not engaged to the flywheel.
