Radiator Overflow Tank repair?
I have a radiator overflow expansion tank on which two of the top mounting tabs have been broken off. I have the broken tabs. Is there a way these tabs can be repaired so that tank can be used securely? Thanks.
the tank is a weak spot on the 944. i paid about 75 for a new one (if you were closer i would give you my old one) from performance products. which means they are less from paragon.
too bad you cant use the plastic bag as a liner in the tank trick on the overflow tank like you can with the washer reservoir.
I wonder if these can be fixed by melting the material from an old plastic milk bottle. In the early 60s perception brought out a roto-molded plastic kayak that was difficult to repair. Some claimed to be able to repair it by melting (welding) material from a platic milk bottle into the crack. ???
No personal experience!
Much prefer to replace my tank before it needs repair (I'd better it REAL soon!!!)!
Jim (who just hand drilled and tapped his radiator to repair it)944S
