Timing belt rubbing rear cover
Old 08-26-2009, 11:08 PM
944Ross
944Ross's Avatar
Removing the crank pulley is a once-in-30,000-mile+ job, and not that hard. Getting the BS pulleys off is harder.
Old 08-30-2009, 01:19 PM
cwjohnson
cwjohnson's Avatar
Hey,guys-many thanks for this timeley-for me as well-discussion.I have
spent far too much money on this problem.I will spare you the details.I
would like to know where one can get this "new" timing belt.This looks like the solution to a very vexing problem.
Thanks heaps! Chas924S.
Old 08-30-2009, 10:21 PM
cwjohnson
cwjohnson's Avatar
OOOPS!What I meant to ask was where can I get this "new" timing belt COVER.
Sorry for the error
Chas924S
Old 09-09-2016, 03:23 AM
alpinewhite
alpinewhite's Avatar
I found this picture in the LindseyRacing parts section
Old 09-09-2016, 08:35 PM
Tiger03447
Tiger03447's Avatar
Sounds like it might be the time for some Dremel work...and some judicious cutting..The dremel rotary saw should make quick work of the plastic..and Voila!
Old 10-05-2020, 01:05 PM
FrontPorsche87
FrontPorsche87's Avatar
Default Top Front engine cover issue too !
After installing the new timing belt (Gates RPM Racing belt , Kevlar)
and the Conti balance shaft belt, tensioners and rollers, the engine developed a whine.
I checked and adjusted the balance shaft belt idler roller for the correct spacing of 0.5 to 1.0 mm.
No noise with cover off, but whines with it on. It turns out it was rubbing at the top balance shaft pulley.
The cover must have warped. I tried grinding the area down but still noisy. I have the full plastic skid
panel underneath so do I need to keep the cover on ?
Old 10-05-2020, 02:52 PM
Gage
Gage's Avatar
Check that you have the balance belt tensioner tightened in the clockwise direction. If not it will put the balance belt out of position.
FrontPorsche87 (10-05-2020)
Old 10-05-2020, 03:19 PM
FrontPorsche87
Thank you Gage, I will look at this. So you're saying that the tensioner would change the angle that the belt contacts the upper shaft pulley ?
Quick Reply: Timing belt rubbing rear cover
