oil pan drain plug porsche 944
easy one for all of you.
Where is the oil pan drain plug on my porsche 944?
Is it the screw on the side of the rigid container.
If yes, man it's bolted out there. I cant unsrcrew it.
If anybody had a picture of it, it would really help
ok, I had the right one, but it's jammed there.
The day Porsche will release a new 944, I will be the first to by one.
damn pre-pre-pre-pre-pre-own
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
1 Post
It should be located on the passenger side of the lower point of the crank case (oil pan)at the rear side. The drain plug will need a new seal part # 900-123-118-30. Buy a couple of them as they are cheap. Check out link below.
http://www.clarks-garage.com/shop-ma...ure-index3.htm
Cheers,
Larry
Cheers,
Larry
