1985 944 AIR CONDITIONING BLOWER PROBLEM: FUSE KEEPS BLOWING
well if its not at the compressor it goes kinda like this
climate control to additional fuse box (2 25amp fuses) to relay to pressure switch to compressor.
I can try and pull up the diagrams later, although when your AC is working and then isn't it is usually the compressor or teh climate control unit.
thanks Sean,
but just to make sure, it's the fan (the blower) that does not work.
I don't no if the AC itself work, because the blower does not shoot any air.
thanks
thanks
Sean,
1. when you say additional fuse box (2 25 amp fuses), where is that located? The one under the driver side dash?
2. The relay, is it under the driver side dash?
3. Pressure switch, where is it?
thanks for your help
ok, I think I found the pressure switch (it's the one connected to the Desiccator, right?)
I tested it with meter and there's no power coming out of there, is that normal.
And if I want to change it, when I remove it, is the Frion gonna spay out of the Desiccator?
