M030 part numbers please
Front Bar - 944.343.706.30
Front Bushings - 951.343.794.05 (2)
951.343.793.31 (2)
Rear Bar - 944.333.701.01
Rear Bushings - 964.333.792.00 (2)
I cannot find the PN for the retaining clips on the front bar. You may want to call Jason@paragon for that. I got the entire setup from them at a reasonable cost, and it came with everything needed.
Enjoy!
951.343.793.31 (2)
Enjoy!
Did they tell you what that part is? Part number does not ring a bell, but it could be the drop links (and you have them with the stock bar. IIRC.. and I hope so, the new bushings will fit into the old drop links just fine.
Your '86 should have one of the smaller bars from the facotry (cannot remember diameter, but it is the same as mine).
As far as I can tell, all I need to do is swap bars and bushings. (part numbers above came off the parts I have from Paragon's kit)
I have not installed it yet since my front suspension is out of the car.
[quote]Originally posted by K27w:
<strong>My local dealer is saying I will need 2ea 951.343.075.00 stabilizer mounting.
Do you know if this is correct ? what is this part ?
Thanks again for the help.</strong><hr></blockquote>
You do_not need those parts - they are the drop-link bushing clips, same on all 944/968 after 85.5.
[quote]Originally posted by Olli Snellman:
<strong>Are the part #'s same for '88 model ?
Olli (and Perry) - the 87+ models all use the same inner bushing carriers (944.343.731.02) - no need for the extra parts.
For those keeping track - front 968 M030 parts upgrade for cars not so equipped:
87-95 944/951/968
Bar (x1) - 944.343.706.30
Lock Washers (x2) - N.021.449.1
Inner Bushings (x2) - 951.343.794.05
Outer Bushings (x2) - 951.343.793.31
*Drop-link bushings (x4) - 951.343.795.01
85.5-86 944/951:
Inner Bushing Clamps (x2) - 944.343.731.02
82-85.1 944:
**Outer Bushings (x2) - 171.411.314.A
* = optional recommended items
** = must be modified to fit, bore to ~20mm
Good Luck!
87-95 944/951/968
85.5-86 944/951:
82-85.1 944:
Good Luck!
