Oil pan bolt stripped...
08-08-2009, 05:28 PM
I put my S2 up on the lift trying to chase a minor oil leak that i noticed and believe that it's a stripped oil pan bolt.
What can I do to repair it?
08-08-2009, 05:38 PM
Heli-coil would work fine there. Probably need to pull the pan to do it right though...
08-08-2009, 08:50 PM
Quote:
Originally Posted by
Tom M'Guinn
Any idea of what size I would need and where to get them?
Why woulld you need to pull the pan?
08-08-2009, 09:11 PM
try a slightly longer bolt.
08-08-2009, 09:13 PM
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
The reason for pulling the pan off is that you will have to drill out the hole so the heil-coil can be installed.
Cheers,
Larry
08-08-2009, 09:27 PM
931guru
Good idea, or a stud you can bottom out, then use a nut.
Threads are standard M6 -- helicoils, studs and bolts available at your local hardware/auot parts stores.
928 ,
bolt ,
bolts ,
hole ,
leak ,
longer ,
nut ,
oil ,
pan ,
porsche ,
size ,
stripped ,
stud ,
threads ,
tool
