Had these assemblies sitting in the garage for way too long. Finally pulled out the old lenses, cleaned out all the black goo and installed the new ones. I had purchased the clear turn signal reflectors a while back and then cut out the orange ones on a spare set of tail lights and glued them in....
How did you cut the lens out? I tried like hell and had no luck? Looks nice, but I would tint that lens red or even the reverse too. On my black car I like the look of red blinker even though my reverse is still clear..
Hmm - I just drilled a hole in them and then used pliers to break out as much as possible. Then I carefully used sharp chisels and razor blades to clean out the glue and so on along the edges.
Originally Posted by potent951turbo
Looks good Josh! What did you use to get the black goo off the paint?
Used a plastic putty knife as it was dried out a good bit. Then used a lighter fluid type product to get the rest off. After that I put a cleaner wax on everything. Probably would be a worthwhile job even if you weren't changing the assemblies - just to re-caulk and clean in general....
Originally Posted by Pure Bob Saget
i hate to ask but where can you get those clear lense's
I got these from a guy in the UK that did a few runs of front sidemarkers in clear and the rear corner reflectors.
