It turns over but won't start
What Kinda job is in changing the Speed and reference sensors. I have been told to check and make sure there is a good connection at the firewall. How hard and where are they located and how long should it take any major tools. Keep'em coming thanks a bunch.
On the back of your motor at the firewall you will see 2 of the same electrical connectors on top of each other. Follow the wires down to the bell housing of the transmission. They will be held in place by 1 10mm bolt each or an allen head most likely a 10mm bolt. Get a long extention. Soak the 10mm bolts with pb blaster and wait a while then loosen each bolt and remove. Twist and pull up each sensor out of the bellhousing and disconnect from the harness. Do 1 at a time so you do not mix them up.
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
1 Post
OK, Go to the link below:
http://www.clarks-garage.com/shop-ma...ure-index3.htm
Go to (S) Speed Sensors A show and tell on the reference sensor and location.
Cheers,
Larry
Cheers,
Larry
