windshield washers
91 S2 Cab: anyone know what the 3-way T connector on the passenger side and 2-way L connector on the drivers side are for? I can't blow through them, but I can see some sort of spring inside. I'm not getting fluid out of the nozzles, but i can bypass these valves/connectors and everything works.
anyone know a reason not to put open T & L connectors inline?
thanks
thanks
They are check valves, without them it just takes longer, holding the switch,dragging the blades across a dry windshield, to get fluid to the nozzles... replacements are available...
Kit $31.50
http://www.944online.com/cgi-bin/ASI...key_1178638574
or just the 90 $7
and the 3 way $10
http://www.944online.com/cgi-bin/ASI...skukey_1000739
Kit $31.50
or just the 90 $7
and the 3 way $10
