two questions...
two questions...
on my 85.5 late N/A
-i dont get clutch engagement until im almost released...and still slips when engaged if i get on it. I do not have any "free play" in the pedal so i would not need to adjust the nut there...but i did notice that the boot for the clutch master cylinder is completely wet...do you think this could be a direct cause of my slipping clutch?
-today i notice that when i go WOT that it dogs right down...coil pack?? cause i do have a MSD blaster coil on there, and the wire does not fit all that well on there.
yea the clutch slips bad when its hot...so im going to do the whole thing...slave cyl, TO bearing, clutch, flywheel and upper hose. so im on the lookout for all those parts. Figure ill do a lightweight flywheel while im in there.
