Strange grounds issue
Howdy,
In the process of chasing some electrical issue with my 951, I checked the resistance between the ground pins on the DME plug, and the negative battery terminal. The result was a resistance of 15 Ohm. I was expecting 0 Ohm.
I next checked the resistance between an actual chassis ground (a piece of bare metal on the roll cage that is welded into the car), and the negative battery terminal. Result: 0 Ohm, as expected.
Doe this mean my DME grounds are in need of cleanup, or is there another explanation?
Thanks in advance for your thoughts!
Gary
Gary
Thanks! Yes, the wire resistance plays into it. But it should be negligible: 18 gauge copper wire has a resistance of maybe 3-5 Ohm -- per 1000 ft...
Gary
Gary
I don't have a turbo... but you should read less than 1 Ohm... Because that is what I get in my 86N/A.
Clean the grounds on the bell housing. Might be easier said than done on a turbo though... lol.
