sway bar trouble
sway bar trouble
so elliott or drift a 944 just gave me two sway bars from a 951. front and rear. but my car doesnt have anything set up for the rear sway bar. so idk how to bolt up this rear sway bar in. is there a kit for this or something?
thanks
thanks
you need drop links, and there should be 3 threaded holes on a mounting plate on your rear axle. thats where you mount the bracket. theres plenty of links and diagrams in the archives.
You can get the factory style ones, however they are $110 a pop if you buy them new. The other "cheap" option is a $70 set of KLA adjustable ones with spherical ***** on the ends. I've been looking at the kla's but i am running in a stock class in autocross so i'm not allowed to use them :P
http://www.paragon-products.com/prod...7.511.051a.htm <--stock
http://www.paragon-products.com/prod...roplinkkit.htm <-- Spherical
You also need new camber eccentric bolts (what the drop links bolt to.)
I'll sell you the eccentric bolts, drop links and the bar mounting brackets all for $75. PM me if you're interested.
