balance shaft tool
Save your money... you do not need that special tool
Any store will have the larger needle nose pliers that are bent 90 degrees. $10 bucks
Open them up.... the ends go staight into the holes with plenty of room to get a socket on the bolt.
</font><blockquote><font size="1" face="Verdana,Tahoma,Arial,Helvetica,Geneva">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Originally posted by AlexE:
<strong>Save your money... you do not need that special tool
Open them up.... the ends go staight into the holes with plenty of room to get a socket on the bolt.</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">I'll second that. It has worked for me several times.
I used the old belt on the sprocket trick. I have a set of vise grips with a very wide jaw opening. Use just enough pressure to hold the sprocket and the bolt will break loose very easy.
Jane Bond 007
Open them up.... the ends go staight into the holes with plenty of room to get a socket on the bolt.</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Too cool!
I bought a two foot steel stake used in setting concrete forms. Found some old allen keys that just fit the holes. Drilled the bar, trimmed the keys to length, heated them with a torch, and used the vise to press them into the bar.
Viola speacial Porsche tool #$*@!... cost < $3 satisfaction endless.
Jane Bond 007
My friend who is helping with my car made the same sort of setup. We're about to go try it out (if I can wade through the snow to the carraige house!). Thanx for the ideas
