strut nut - locking washer?
I replaced my Koni inserts this weekend. The strut nut that came off the old insert seemed to have a different thread pitch (they'd go on a little, then get really tight. I didn't want to push them).
So, I used the nuts that came with the new inserts. There were lock washers in the package with the nuts. Should I use them?
Herr Unmöglich
Might not be a bad idea. I did not use washers when installing my camber plates... though the nuts did not back off they were not tight when I went to remove things in the fall for winter maintenance.
