Clunking from the rear
Old 07-13-2009, 02:47 PM
86 951 Driver
86 951 Driver's Avatar
Default Clunking from the rear
What would cause a clunking in the rear of the car? Its not all the time. I heard it only once today on the way to work? Would it be a CV or something else.
Old 07-13-2009, 02:55 PM
83 944's Avatar
the cv bolts are probably loose.. its common . tighten them up and see possibly tranny mount?
Old 07-13-2009, 03:25 PM
86 951 Driver
What is the right tool to tighten the bolts on the CV's?
Old 07-13-2009, 03:27 PM
krystar
krystar's Avatar
8mm 12pt triple square
Old 07-13-2009, 09:19 PM
IGROWL
IGROWL's Avatar
Just for fun check your spare tire to make sure it is in there tight. Every once in a while I would hear a clunk from the rear. Than one day I had a flat tire and I went to get the jack out and found the loose tire. Now that it is tight no more clunk.
Old 07-13-2009, 09:38 PM
PXJ800
PXJ800's Avatar
I had an occasional clunk, turned out it was a loose sway bar.
Old 07-13-2009, 11:14 PM
mikey_audiogeek
mikey_audiogeek's Avatar
Could be caused by a dodgy transmission mount: https://rennlist.com/forums/944-turb...ion-mount.html
I've got a similar problem - occurs during cornering, 1 clunk or 2, only repeats when cornering the other direction - ie probably something taking a set. I've just urethane-filled a standard mount, to be fitted this w/end.
Cheers,
Mike
Old 07-14-2009, 01:29 AM
83 944's Avatar
eek ..yeah i have a strange clunk in the front. but then again i ahve a bent strut yay!!
Quick Reply: Clunking from the rear
