oil sensor questions...
i have an 85.5 late N/A
where is the stock oil pres and temp sensor locations?
where is the Air Oil Separator? i've prob looked at it a million times, and dont know it...just want to make sure i didnt accidently delete it haha
im thinking of tapping the stock temp or press sensor for aftermarket gauges sending units. I would much rather do that than buy a drain plug adapter.
once i get these two done, then i can order my fuel level, fuel pressure gauges and be done with my whole console...everything else is done on the dash
ok well i found out where the oil pressure sender is...but still trying to figure out what each of the leads does for it...because if its just a thermocouple, i can use the stock sender and wire it to my aftermarket gauge im assuming
EDIT: NVM about the pressure sensor, ill just have to get a 1/8MPT female to M18 x 1.5 male adaptor tomorrow...i found the thread info on the pressure sensor in the books.
still looking for the temp sender.
