crank woodruff key
Almost Addicted
crank woodruff key
OK, the two in the balance shafts were cake, the one in the crank is not coming out. I have used the front cutting snips, screw drivers, etc. with no luck. I am going to try a larger pair of front cutting snips than I had today, but if that fails...
1. can I just grind the exposed part down to free the gear or does the key actually protrude laterally into the gear?
2. where can I buy another one?
3. are there any other methods that I am missing?
Herr Unmöglich
pb blaster overnight. then dry it off, and try the end cutters. either that or a small light hammer and a flathead screwdriver are all i have ever needed.
My PO or his mechanic mashed mine pretty well. I had to take a very small cold chisel and tapped in a groove on both sides of the key, then a pair of long handle side cutters gripped in those grooves (my radiator was out, so it was easy with the long handle). Got a replacement from Paragon for $2
Almost Addicted
Almost Addicted
