944S2 oil change question
Old 06-27-2009, 01:44 PM
944S2NUT
944S2NUT's Avatar
Default 944S2 oil change question
Just wondering if there are any tricks that I should do to remove the vertical oil filter. Also will I need any special tools for the job?
Oh ya, how many liters of oil does the S2 take? I can' seem to find my manual atm. :S
Thanks guys
Old 06-27-2009, 01:52 PM
smlporsche
smlporsche's Avatar
Oh no not another oil question !!!! J/K
The only trick I know of is to take a small screwdriver or similar pointy device and pierce the top of the filter to let it drain a little better. I still stuff alot of paper towels around it and I still get it everywhere...
It takes 6 qts with a filter.
Kev944Cab (01-12-2022)
Old 06-27-2009, 02:24 PM
944S2NUT
944S2NUT's Avatar
Thanks man appreciated
Old 06-27-2009, 02:26 PM
Bruno'S2
Bruno'S2's Avatar
Good one sml. My oil question was pretty much answered.
I use a tool to remove/install oil filters I purchased at Canadian Tire. It looks flimsy being a strap attached to a square tube but it works great in the cramped area we have to get the filter in and out. You get the strap around the filter and use a 1/2 in ratchet to turn the square tube around. Works well.
Old 06-27-2009, 02:57 PM
choinga
choinga's Avatar
I tried poking the oil filter and then letting the car sit for over 30 minutes to try to get everything out of there - I still got a ton of oil coming out of the filter so I think that is bogus. Theorhetically it should work - but YMMV.
Just make sure you stuff a bunch of rags down there as mentioned and you might want to turn the headlights on to get some stuff out of the way. I even thought about loosening up the power steering resevoir the next time just to get a little more room... Just turn with one hand and have a rag in the other and as soon as it comes free slip your hand with the rag under it and get it out of there pronto.
Old 06-27-2009, 03:23 PM
theiceman
Team Owner
theiceman's Avatar
Received 1,047 Likes on 746 Posts
I used to do the following ..
lift the lights . it moves some stuff out of the way so you can work a bit quicker ...
after loosening it i would put a plastic grocery bag down over the hole thing .. when the filer falls off it falls into the bag with most of the oil, pull the bag out and tie it in a not ... done . Not pefrect but way better than what I did before
Old 06-27-2009, 03:24 PM
944S2NUT
944S2NUT's Avatar
This is all great info! I will let u know how everything goes.
Old 06-27-2009, 04:51 PM
Wipeout
Not Special
Wipeout's Avatar
With an S2, i disconnect the coil wire. Just be sure to reconnect it before trying to start the car!
Old 06-27-2009, 05:05 PM
KuHL 951
Hey Man
KuHL 951's Avatar
+10 As unelegant as it sounds it works very well and keeps spillage to a minimum. I use the heavier plastic bags with handles and wrap one side around the mount as best I can. I've also tried the punched hole trick and was not impressed at all, either was my garage floor
Old 06-28-2009, 01:24 AM
gtroth
gtroth's Avatar
I do what theiceman does plus:
-put some kind of protection over the front of the car in case you drop something (I use a little cloth rug).
-I use rhino ramps
-autozone sells the steel cap-type filter wrench that fits the mahles (oem type B I think). It's thin walled so it doesn't need much space.
-car should be warmed up (hot oil - use a heavy glove when you remove the drain plug.
-new crush washer on the drain plug every time, and use a torque wrench. I use anti-seize.
Old 06-28-2009, 02:30 AM
944S2NUT
944S2NUT's Avatar
I got the bloody thing off! I tell yah, that oil filter took a few years off my life :S what a bitch.
I bought that oil filter removal tool, what a waste of money! I ended up pinching the top of the oil filter with a massive set of plyers and turning it lose, lol.
Old 10-08-2011, 04:12 PM
jep32
jep32's Avatar
I put 7 quarts of M1 15W-50, and I'm just at the top of the "upper" notch. Do S2's have the 7.4 qt capacity or the 6.8 qt capacity????
Old 10-08-2011, 06:27 PM
ernie9468
ernie9468's Avatar
_____You simply didn't buy the rigth tool ,what you need is this (see pics) couple to a 6" -3/8 extension or longer,in a matter of second the filter will come out.It's made easier by removing the coil wire from the dist cap & tuck it aside.Before changing the filter on any 2.5/3.0 ltr you want to stuff paper towels all around the bottom of it ,also cover everything you think the oil is gone to drip on (from the steering boot/power steering hoses/fenders ect ect.
_______
Never mind all those # put in 6 quarts start her up & go by your dipstick add if needed.Minimum mark is (RED- lower) Maximum is ( WHITE -upper).You can drive the car with the oil between them two marks without hurting it.But I wouldn't recomended. I like to keep my oil on the top mark. You can't never never drive it with the oil below the Minimum mark.
Old 10-08-2011, 07:17 PM
ernie9468
ernie9468's Avatar
Wink
Yes I know old thread revival ,just notice.Oh well can't win them all.
Old 10-08-2011, 10:27 PM
HICKS
HICKS's Avatar
Ernie who makes that filter wrench? I havent seen a metal one thats long like that. Do you have a part number on it? Thanks!
Quick Reply: 944S2 oil change question
