Dang. Too bad you guys are soooo far away. I have an 87 n/a tranny and a 86 turbo tranny sitting on the ground in my garage taking up space. Only the 85.5 and later will fit since the trans mounts up differently and the aluminum case is casted differently as a result. Good luck.
