Brake rotors
Brake rotors
Are brake rotors different through the years? I am lookin at some on ebay and they don't have 924S or 944 rear rotors for the early years. Here is what I am looking at would these work?
Fronts
http://cgi.ebay.com/ebaymotors/PORSC...Q5fAccessories
Rears
http://cgi.ebay.com/ebaymotors/Porsc...Q5fAccessories
Or would there be another place to get some cheap rotors.
Fronts
Rears
I just bought a set of slotted rotors from them for my Explorer. Haven't received them yet, but I haven't seen any negative info on them. Everyone seems to love them. Why get the blanks when you can get their drilled/slotted edition? I'll give a report when I get them on the Exploder and are broken in. Most people pair them up with Hawk pads. I'm trying Wagner Thermoquiets.
[QUOTE=Lizard944;6658489Why get the blanks when you can get their drilled/slotted edition?[/QUOTE]
Because drilled crack sooner, and both wear out pads sooner.
It's a cosmetic upgrade with a price to pay.
Unless you are racing the car and don't care about the consumable costs, you get "blanks". Because they work. And on a DD, you won't (CAN'T) notice a difference, unless you are deluding yourself.
It's actually normal for a rotor to develop surface cracks (hairline) due to the expansion of the surface. It's not a problem as long as they're tiny and do not connect.
It's all folklore but I've also heard that cross-drilled rotors are more likely to crack. My "common sense" conclusions is that both camps are correct. Cross-drilled rotors DO offer more surface area and voids for airflow, and probably do provide better cooling. You can't find a race car without drilled or slotted rotors; and they don't care about cosmetics.
Better cooling is good in extreme conditions (racing), but irrelevant (or even a negative) when stopping on cold brakes.
But if you drill holes in something, you make it weaker and more prone to cracking. You also reduce the friction surface.
For street cars, the benefits of cross-drilling will never be used. But they do look cool.
