Seriously failed smog test - Update 6-/18
Hey Man
Yeah, another stupid failed smog post. I just got back from smog testing my 86 951 at the same 'test only' facility I've used for years. It failed miserably in every category except HC at 25mph. I'm talking a car that passed 2 years ago with the same set-up except I swapped the stock airbox on this time. I'm thinking the O2 sensor is toast and the cat is probably burnt out from running rich. The car was fine 2 years ago with the same VR K-26/8 chip and 3-bar FPR. I have another cat section and 2.5 FPR I can throw on but not sure if that is enough. I'm not sure if changing the FPR will make it too lean at 15/25 mph with the VR chip or not. I've added xylene on a past test with good results but I've heard it can make the NOx go up dramatically. Any thoughts always appreciated?
15 mph:
HC: max allowed 133, measured 222
CO: max allowed .82, measured 2.32
NO: max allowed 1125, measured 111
25 mph:
HC: max allowed 108, measured 121
CO: max allowed .62, measured .89
NO: max allowed 955, measured 1177
15 mph:
25 mph:
older than 1997? WTF!
Edit to add insight: Last time failing across the range happened to me, it was a cat. I don't recall which vehicle though, I"m pretty sure it was the 944.
Not Special
This sounds like my '85 when I registered it up in Oregon. It'd passed the CA smog the previous year, then failed up here miserably. Replaced O2, didn't even register on the smog test it was so perfect. There's extra witchcraft I'm not familiar with on turbos, though.
Yes, I run it in that conc. in all my vehicles. On the fuel injected vehicles which atomize the hydrocarbons well, it is not noticed much at the pedal, But out the tail-pipe analyzer..... NOX is nada.
On my carbeurated bikes, there is an increase in horsepower because of the complete combustion that it causes of the hydrocarbons. The Acetone molecule is a turbo-charged propane if you will, with it's own double bonded oxygen (liquid turbo)
lol, +1 on the acetone. Its cheating, but it works.
Did you drive around for a while before your test. Your cat has to be plenty hot to pass some tests.
Hey Man
I'm sure a new O2 sensor will make the biggest difference of all. Is the O2 sensor more critical for low rpm fuel control than higher rpm? Since my emissions improved some at higher speed it has me wondering. Is there a way to test the O2 with an ohmmeter at the plug. I've tested them on a BMW but that was years ago and my memory sucks. Something about the hot/cold difference and how fast it dropped at idle.
Yeah there is a way to test the O2. Its not an exact test but it works.
Warm the car up so the O2 sensor is nice and hot. Then unplug the sensor. Set your Ohm-meter for 2000mV or something of the like.
Connect one end of the meter to the male pin on the sensor wire (should be 2 female pins and one male), and connect the other end to the negative of the battery.
It should read somewhere between 500mV and 850mV ish. Now richen up the mixture either with propane or w/e you wish that will make it rich. The sensor should now read above 900mV. Now lean the mixture by disconnecting a vacuum line at the intake. The sensor reading should quickly drop to 200mV or less.
Mine was bad and it read 880mV at all times. I replaced my O2 recently, and while it was a huge improvement I only got close to passing NJ emission.
My n/a is currently only slightly lower than yours. I passed everything but the CO%. I need .50 and got .82.
Oh yeah... im pretty sure clarks also says to run the engine at 2500 rpm during the test. But I've tested good and bad sensors, and the test proves efficient at idle too.
All testing done on my 86 n/a if it makes a difference.
