wheel bearing repack?
yea pep boys had a packing tool for $11. doesn't require a grease gun. was easy to use. and had a dust cover for leftover grease too.
i think it was this..or a pretty good knockoff.
http://www.amazon.com/Lisle-34550-Ha...3611976&sr=8-2
Yeah, the packing tool work well. I just do it by hand. I don't grease bearings enough at home to worry about the packer tool.
Also, if you tighten the hub nut finger tight, you can still wiggle the washer with a small screwdriver. Don't crank on it with your hand. It truly is just finger snug.
