600hp 951
</font><blockquote><font size="1" face="Verdana,Tahoma,Arial,Helvetica,Geneva">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Originally posted by John Anderson:
<strong>"ok lets see... built by Norwood Performence (Doom Car,)968 block sleeved to 2.6, 10:1 compresssion, 24 lb of boost "
so lets see, all this stuff about dropping the compression (according to the listers, this is the ONLY way to safley boost a motor) in my customer 968's/S2' while adding my turbo conversion is what?
Gee, I've stood by my beliefe that boost and compression can be mixed up a bit :-0
I guess I'll just keep building'um :-)
Stay tuned :-)</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">I don't think you can compare your turbocharged 968 motor to a norwood motor.... It is just not a fair comparision stock 968 w/ a bolt on turbo vs a couldn't be more motified highly specialized 2.6L 968 Motor producing 600 hp.....
</font><blockquote><font size="1" face="Verdana,Tahoma,Arial,Helvetica,Geneva">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Originally posted by ian:
<strong> </font><blockquote><font size="1" face="Verdana,Tahoma,Arial,Helvetica,Geneva">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Originally posted by John Anderson:
Stay tuned :-)</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">I don't think you can compare your turbocharged 968 motor to a norwood motor.... It is just not a fair comparision stock 968 w/ a bolt on turbo vs a couldn't be more motified highly specialized 2.6L 968 Motor producing 600 hp.....</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">thats what i was thinking...
<strong>I don't think you can compare your turbocharged 968 motor to a norwood motor.... It is just not a fair comparision stock 968 w/ a bolt on turbo vs a couldn't be more motified highly specialized 2.6L 968 Motor producing 600 hp.....</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Don't be a fool. He's not saying that an 11:1 stock 968 engine can make 600 horsepower at 20 psi. He's saying that if Norwood can build a motor with 10:1 compression and run 24 psi, then he can SURELY do 3-6+ psi on an 11:1 engine no problem. We wouldn't be doing this with an 8 valve motor, the spark plug location and pent roof design of the 16 valve heads are superior to the 8 valves [need I translate this as meaning more reliable?]. Some of you guys are just too much...
</font><blockquote><font size="1" face="Verdana,Tahoma,Arial,Helvetica,Geneva">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Originally posted by PorscheG96:
<strong>Don't be a fool. He's not saying that an 11:1 stock 968 engine can make 600 horsepower at 20 psi. He's saying that if Norwood can build a motor with 10:1 compression and run 24 psi, then he can SURELY do 3-6+ psi on an 11:1 engine no problem. We wouldn't be doing this with an 8 valve motor, the spark plug location and pent roof design of the 16 valve heads are superior to the 8 valves [need I translate this as meaning more reliable?]. Some of you guys are just too much...</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">I'm not saying that he was suggesting that his motor will make 600 hp, I was saying comparing the two designs is pointless. He used a 600 hp 2.6L 10 to 1 compression race motor to say that putting a turbo on a stock 968 was ok. I just find that to be a very flawed argument.
