And so it begins.........
<img src="http://boards.rennlist.com/upload/itbegins.jpg" alt=" - " /> <img src="http://boards.rennlist.com/upload/navagation968.jpg" alt=" - " />
I was suprised the 996 navagation fit right in where the radio and compartment are, the CD part will have to go in the glove box, unless I can think of a better place to put it. Just wanted to give ytou guys a gilmpse on what is to come....
SANDOVAL,
I am also picking up where you left off on the 993 litronic upgrade. Not sure HOW I will accomplish it yet, but I will keep you posted on it! Might take awhile though, as it is not a priorty now. What did you do with the 993 housings?
SFR stage4 Garrett ballbearing 60-1 HI-FI with a # 10 hotside. Just small enough to keep A/C, and have a MONSTER top end. Also I will be using TWO diffrent motors and trying two diffrent hotsides.....I will be trying a #8 also. One motor is a stock 968 turboS (block and head), and the other is a custom that I am still working out the details, some of which are posted on the turboS page. We will see which works best.
I took mine back... Unless you plan on cutting your fender and doing major bodywork it will be very difficult. then you will have the beam angle to deal with. I decided it was more work then it was worth the other thing is the the 993 bucket looks as if it will hit the fenderwall on the interior of the fender so that will need to be cut out... it is a huge job. good luck though!
Turby, may have the honor of simply touching your turbo? Please!!
OK... OK... can I just LOOK at it? I wish I had the time and $$ to
"play arround" like that.
