drilling holes in airbox
Why drill the holes? I suppose the cost is zero for one. Just get rid of that big black monsterous box and go with a cone filter. It will really open up that side of the engine compartment.
nh3
nh3
has anyone made the stock hole that the box leads to for air bigger and stuck a cone filter in there? looks like an obvious way to go....I'm sure it would be popular if it was jsut that easy...
alright, airbox mod completed. i used a hacksaw and a leatherman to cut apart the airbox, then sanded down the rough edges and spray-painted it with 2 coats of high-heat gloss black.
i used the metal frame to an air filter for a furnace (that happened to be the exact same dimensions as the air box) as the inside edge, and some wire mesh as the covering. i made the wire mesh into a big cube without a bottom that was the exact size of the air filter, then stuck it on the filter. i used double-sided tape to mount the metal edges on the inside of the airbox frame, and then put the frame over the filter.
total cost was about $5... thanks to skip for the inspiration. oh, and don't laugh at my paper filter... i'm gonna buy a k&n in the next couple of days, i swear.
opinions?
opinions?
im actually right now working on carving a porsche crest into my airbox,![](http://www.geocities.com/rizzy_rizoo/airbox1.jpg)
once i do that im going to put wire mesh behind it then put some lighting inside the box to make a glowing crest shape in my airbox. ill get more pics as it develops. right now my freakin hand hurts form using this little saw i found.
