Its a flood!!!!!!!!!
Took the new turbo out on its madien out of town trip yesturday. I drove about 175 miles on the highway with out stoping. When I
exited and made a left hand turn I had about a 1/3 gallon of cold water dump out into the passenger floor. I plan on checking the
drain comming out of the firewall but just wanted to ask if this has came up and is there anything else I might check.
If you were running AC, it's the drain from the AC system. Water collects under the condenser and spills when you make a turn (right turns soak your feet!)
The solution is to pull out the radio and cubby below. Behind it, you will see the bottom of a black container with a short (3") rubber hose coming out of it and heading through the floor.
Pull the hose off the container (this will cause a big flood so have paper towels handy.)
Then (Thanks to Billybones for this solution) use an E string from a guitar to ream out this hose. Guitar strings are nice because they have a ball on the end so the string itself will not catch on the rubber hose. Hope that helps!
