Crest gasket issue
Crest gasket issue
I installed a new hood crest the other day the gaket keeps moving on me. The crest is down tight but the gasket slides around. Did I do something wrong ?
NOW your problem is you have spread the pins apart by pushing on the middle of the face of the crest, the pins need to be "reset" back closer together... If on an N/A you can get to them from the engine bay without removing anything, just need a long screwdriver and a flash light, on a turbo, pull of the header panel...
YES it can be fixed, but you have to think outside the box on this one... I did the same thing to the new one I installed to my N/A... when I did the turbo got it right the first time... I don't know why it doesn't come with instructions or at least a read ahead message from the sellers of them... ONLY push on far enough to secure the gasket, push all the way and you bend the crest and end up with how it looks now... Back up a step or two, try again...
My trick to install the emblem gasket is to put strips of blue tape on the back side, so I can tug the gasket edges out. Once the emblem is seated and done, I gently yank and the tape comes out.
I used a little krazy glue on mine and it's nicely lined up all around. It's also a good idea to spread the pins apart just a tad before inserting, so the emblem grabs onto the panel better.
