Turbo Twist wheel question
Ok, i know this question has been asked a dozen of times. I believe i might had asked once before, but i want to be crystal clear on my options.
On a 1986 951, will a 911 fuch wheels fit. example 1979 -1989 fuch wheels, is this correct?
If yes, then i would assume the aftermarket turbo twist that fit on (1979-89) 911's will also fit on an 1986 951, is this correct?
Then if i am correct, the OEM turbo twist will fit on 1987-plus 944's, 951's.
but would fit on an 86 944 if spacers were added.
Ok, so am i all wrong or half right....
HELP Please. (spacer dimenstions won't help, comparing 911 wheels with my car will)
thansk jpc
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
thansk jpc
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
Geaux Tigers!
If you cannot find the offsets via search then give me a little bit and I'll go get them off of my 86 spec twists. They are currently packed away and upstairs so it'll take a bit.
