View Poll Results: wheel spacer poll...
1 inch spacer w/longer studs
![](https://rennlist.com/forums/images/polls/bar2-l.gif)
![](https://rennlist.com/forums/images/polls/bar2.gif)
![](https://rennlist.com/forums/images/polls/bar2-r.gif)
![](https://rennlist.com/forums/clear.gif)
2
33.33%
1 inch spacer with studs integrated
![](https://rennlist.com/forums/images/polls/bar3-l.gif)
![](https://rennlist.com/forums/images/polls/bar3.gif)
![](https://rennlist.com/forums/images/polls/bar3-r.gif)
4
66.67%
Voters: 6. You may not vote on this poll
wheel spacers poll....
Captain Obvious
Well, what say you?
1 inch spacers with longer studs, or 1 inch spacers that have studs integrated, and bolt onto the original studs...
mine has studs allready integrated into them, so that is what I will choose
as opposed to some REALLY long ones, I think its "safer" - but I really don't know - so I'll be watching this thread as well
Just a car guy
The key is maintaining concentric mating of the hub. If you can get away with a spacer that has this feature along with the longer studs - it is as good as the other option. If this is not feasible or an available option - then I would definitely recommend the spacers with integral studs.
Note: Any proper spacer will need a machined ring to accept the hub flange on the vehicle and then a corresponding lip on the other side to match the wheel. If these mating features do not exist - you are relying on the wheel nuts and studs to align and center the wheel on the vehicle. This latter condition is not desirable.
