Cracked Header
Assuming that you have a 951, I beg to differ on welding the headers. They are stainless steel, so whoever does your welding must be very good at stainless. Mine had several cracks, a friend here fabricates stainless fixtures for restaurants and welds constantly. He welded them up, they haven't cracked again thus far, one year and quite a few hard miles later. Then again, you could always buy a new set from B&B ($1k+ I think) or gamble on a used set.
If you do have them welded, I highly recommend that you remove the factory heat shields, since there is also likely to be a crack under there too. Go back with DEI header wrap for insulation. It works better for me than the factory shields.
My headers were cracked-
1-broken off the flange of #4
2-cracked in both the "Y"
3-2/3 cracked at the collector
4-cracked at the flange of #2
If you do your own wrenching and have a welder that you trust, this won't be expensive at all, just time consuming. The other option is to throw money at it. HTH
Dave
Dave
If you weld the headers back together, make sure you have it done by someone who's familiar with thin-wall steel welding. That pretty much rules out all the guys at muffler shops. You need to heat up the part first, then MIG/TIG it (no slag rod-welding allowed) and cool it down slowly afterwards. Then you need to file/grind down the weld to remove all the stress-risers.
But that may not solve the actual CAUSE of the crack to begin with. Which is the differential expansion rates of a steel header on an aluminium block (steel expands less for same temp-increase). One way around that is to slot the bolt-holes on the header. Then attach it to the block with a spring between the bolt and header. Don't tighten it down all the way so that only spring-tension pushes the header against the block for a seal. Then as the block expands, the header-to-block interface is allowed to slide against each other; no stretching of the header allowed!
